Testing of PSVs in Steam Service
While PSVs in Hydro carbon services are permitted to be shop tested using Compressed Air or Nitrogen, why Steam valves are not permitted to be tested the same way? Why PSVs in steam service necessiraly to be tested with steam as test medium or in-service tested after installation at site?
If service temperature vis-a-vis ambient temperature is the reason, we have temperature corrections in CDTP. At the same time, high temperature hydrocarbon service PSVs do not mandate in-service testing again after cleared from bench testing.
Or is it something related to mass flow rate (lb/hr or Kg/hr)?
Could any one clarify on above or lead me to any code references?
thanks,
ravi.
thanks,
ravi.
RE: Testing of PSVs in Steam Service
But am no way certain about this
