NX8.5 Shell - Preview could not be computed
See attached part file. I'd like to shell the solid. Solid is made by through curves mesh and extrudes + sew. I am able to shell to thickness 0.01 mm, however I'd like to have it shelled to 3 mm. What can I do to be able to do this?
Thank you for your help
RE: NX8.5 Shell - Preview could not be computed
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tried to make t into more parts, but when I add thickness to just some of the faces some material is added outside some of the other faces, and it is hard to trim this away. Will try some other ways too, but what I actually want to have it 3 mm all over to make a 3D-print, so if there is an easy way to achieve this I would be happy to know.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
