NX4 on Win7 64 bits
NX4 on Win7 64 bits
Do not laugh, I really need to install NX4 windows 7 64 bit
I need it before a customer migration
Is the below version compatible ?
Didier Psaltopoulos
http://www.psi-cad.com
RE: NX4 on Win7 64 bits
Tomas
There are a few threads in eng-tips about it. Biggest issue I recall is getting the license service installed, not difficult to do, just a process to follow.
Try it and if you get stuck, I reckon I can help you out to get it working.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for your answer. I have an issue with the license. I was looking in older thread
Didier Psaltopoulos
1. Copy all license server setup files from the NX4 install DVD to your local hard disk.
2. Delete lmgrd.exe from the files you've copied.
3. Copy the lmgrd.exe from the NX6 or NX5 flexlm install in to your local copy of the licensing folder.
4. Select lmgrd.exe, right click to access the properties using MB3.
5. Check Administrator privilege button.
6. Then run the setup using your local setup that you copied & modified.
Anthony Galante
I had found your last thread and was able to install the license with lmgrd.exe from NX9 folder in step 3.
At this time, I am waiting from GTAC for an up to date NX4 license, because I have upgraded my MACH2 Prod Design to MACH3 Ind Design.
Didier Psaltopoulos
I have got an up to date NX4 license and NX4 works well on WIN7 64 bits
Didier Psaltopoulos
