UGNX 9.0 assembly translucency issues
Hi.
I have noticed a problem when switching from NX8.0 to NX9.0. I work with assemblies quite often and found that I am unaware to make my work part transparent in order to use other components as reference. It seems that the external faces of the work part cannot be made transparent. I have never had this issue before when using 8.0. Has anyone noticed this?
I created an image showing 8.0 on the left side and 9.0 on the right side.
Ryan
Ryan
RE: UGNX 9.0 assembly translucency issues
It's difficult to respond since there are multiple options to apply translucency.
"See thru layers" ? - In both NX8 and NX9 ?
Tomas
I have tried to toggle the "see-thru all" icon, but this does not help. I'm wondering if there is something in the customer defaults that is different between the two versions of UG.
www.nxjournaling.com
thanks!
Menu -> Preferences -> Visualization Performance -> General Grpahics
...to see if the 'Disable Translucency' option is toggled ON?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
