Help in my knee exo-skeleton project
Hey guys, im trying to design a knee exoskeleton which serves to reduce the impact on the knee joints. The purpose of this exo-skeleton is NOT to aid in running but it serves to reduce the impact taken by the knees so as to reduce wear and tear and degradation of the knee. The target audience would be the elderly as well as people who suffer from knee pains, joint problems.
- My request to you guys would be if you could please let me know what are the important factors that i should take note when designing the exoskeleton ( maybe even provide a simple sketch , that would be great! )
- also do let me know the main forces that act on the knee and how i should design the exo - skeleton to counter-act these forces.
- also do point out anything major that i may have missed and would be important to include in my design.
Thanks so much guys and do hope that you can help me in my project :D
RE: Help in my knee exo-skeleton project
Rob Stupplebeen
www.optimaldevice.com
https://sites.google.com/site/robertkstupplebeen/
I would start with an existing knee brace design and modify from there.
I hope this helps.
Rob Stupplebeen
They all suffer from the same deficiency; rotation in service. Most of them include a hole, sometimes padded, that surrounds the kneecap, which is apparently intended to serve as a key. It doesn't work; after several hours, the braces have worked their way around so that the hole no longer aligns with the kneecap, and then the braces with landau bar hinges on their sides have put one of the landau bars in front of the kneecap and the other behind the knee, so the knee can no longer rotate at all, and the pressure on the kneecap becomes painful.
You might do well to spend some hours hanging out in a shop where artificial legs are fitted; their alignment and retention needs are obviously critical, and some clever solutions have been devised to deal with the anatomy|mechanism interfaces.
Mike Halloran
Pembroke Pines, FL, USA
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
TTFN
TTFN
