Temperature field.
Temperature field.
Temperature field.
Hi. I've attached a abaqus analysis on witch i'm working. I need to apply a liniar temperature field that has on the inside of the triunghiular shape the temperature 300 Celsius degrees and on the outside the temperature is 200 Celsius degrees. How do I do that in Abaqus? Thank you
