Ground Fault Setting
In any electrical code, is their a limit that the setting of a ground fault protector to be maximum say t(s)= 1.0 and I(g)= 1.0 . Is their any calculation? The breaker rating is 150A.
see attached. Our inspection is asking a setting calculation.
RE: Ground Fault Setting
Common sense and good practice dictate that in an impedance grounded system your setting must be lower than the calculated ground current.
Bill
"Why not the best?"
Jimmy Carter
The ground fault settings have no effect on arc flash calculations as arc flash calculations are considered 3 phase. The exception to that is in utility type situations (overhead lines) where the arc flash is predominately single phase, open air type faults.
