CANBus interface circuit
Hi
I have some motors that can run using CANBus protocol. Type of CAN they use is Raw CAN where it has just a CAN High and a CAN Low and a 120 ohm resistor to terminate.
I don't have a board that can send CANBus signal yet, and I really love to be able to create one.
Could you please guide me to a tutorial or website that can show me how to create a circuit board that can allow CANBus protocol communication.
RE: CANBus interface circuit
Dan - Owner
http://www.Hi-TecDesigns.com
Introduction to the Controller Area Network (Texas Instruments)
www.ti.com/lit/an/sloa101a/sloa101a.pdf
thanks
... except by the principle that people who have done boards from scratch tend to buy off the shelf whenever possible, as a result of lessons learned at considerable cost.
I suggest that you start with a standalone isolated embedded system of some sort. Presence of a CANBus interface suggests that you want to connect to, >and may possibly unintentionally harm<, connected devices that you do not wish to replace. E.g., if your CANBus connected device burns your new car to the ground, you still have to make the payments.
That said, good luck and have fun with your project.
Mike Halloran
Pembroke Pines, FL, USA
https://www.sparkfun.com/datasheets/DevTools/Ardui... But, you can get the shield itself for 39.95 https://www.sparkfun.com/products/10039
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Or if you want to talk directly to your motor over a usb port, there are lots of usb can adapters. We like IXXAT around here.
Z
