NX pkg files...............
What the meaning of "pkg" files, when should they be used and why?
MZ7DYJ
NX pkg files...............NX pkg files...............(OP)
What the meaning of "pkg" files, when should they be used and why? Thanks MZ7DYJ Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: NX pkg files...............
If you are talking to package file (.pcf), here is the answer:
You can generate a .pcf from your assembly then open it with viewer xpressreview available from siemens (free)
this viewer show the 3D and the drafting
Didier Psaltopoulos
http://www.psi-cad.com
I got a related assignment (create a pkg file) 1 month ago.
It was an assignment for one of our companion's client.
I was suppose to create a new Master Model (Drafting) from an assembly that had about 50 components.
I was told that I had to convert all the components of the assembly into single component, only.
Finally, I've created was I suppose to do, but I have to admit that I wasn't sure why an assembly should be converted into a file with "pkg" (12345678.pkg.0001), with "Body" parts from the conversion of components.
I thought that the reason was privacy............
But I am not sure!
Here's the structure (symbolic)before conversion:
12345678.dwgfmt.0001
*12345678.mlasm.0001
- 1xxxxxxv.mldes.0002
- 5xxxxxxt.mldes.0001
- 7xxxxxxi.mldes.0006
- 9xxxxxxp.mldes.0002
- 1xxxxxxb.mldes.0003
- 4xxxxxxm.mldes.0002
- 6xxxxxxn.mldes.0001
- 3xxxxxxe.mldes.0006
- 1xxxxxxa.mldes.0002
...And the final structure that I was suppose to create:
*12345678.pkg.0001
Thanks!
MZ7DYJ
I think that you are talking about IDEAS conversion, is not it ?
Didier Psaltopoulos
MZ7DYJ
Where is this pkg function in NX ?
Didier Psaltopoulos
Based on the discussion, I'd guess that "pkg" is not a special function or file type; but rather just a designation used within the file name to help identify its contents. Similar to how some companies use "_dwg" in a file name to identify drawings (or "_asm" for assemblies, "_sld" for solids, etc).
www.nxjournaling.com
You are perfectly right!
MZ7DYJ
Can you elaborate?
Why should "pkg" name be used? In which circumstances?
MZ7DYJ
You got to the point, thanks a lot!
MZ7DYJ
