Global deformation from a text doc
I have a couple of questions in regards to using Global Deformation:
If a points file is used do I still need a vector? Or does Global Deformation ignore the vector?
Is there a program out there that combines two exported AutoForm files into a text document that Global Deformation can use?
Thanks in advance,
Kevin
NX8.0
Thanks in advance,
Kevin
NX8.0
