Etabs area spring
Etabs area spring
Hello mates,
Please i want to perform a soil structure interaction in etabs 2013. I have assigned area spring of 60000KN/M2/M, in the 3 direction, is my definition correct. I was confused if the modulus of subgrade needs to be negative.
I also want to know how to place a restraints in the x and y direction of the raft.
Thank you.
Thank you.
RE: Etabs area spring
Indeed it is important when considering uplift on base slab to ensure that the "soil" is not going into tension. So why is it, that when I model my basement structure (held in place with tension piles) and tick the non linear "compression only" box for an area spring I seem to get the soil giving tension reactions?
Any ideas?
J5
@avecillasjavier, please what value should be used for the restraint in the X and Y direction. What I did was to select the nodes of the raft and assign only UX AND UY. What about that?
Regards.
One thing to watch for is if you have an uplift case (fluid pressure uplift) you may want to watch your load patterns/cases. What was happening in my building is in the Hydrostatic case i had no moments because it wanted to lift up the building and there was no resistance since it only looked at that load case.
