F436 Hardened Washers
I am looking into possibly producing a mass amount of f436 hardened washers for a job coming up..6" plate washers with a 4" ID hole. From everything I can find they don't give me the yield strength of f436, mainly because this material is under compression, but I'm trying to see if I can find a steel that has comparable characteristics so I can cut these out on the plas table. I know this is a hardened steel but does anyone know of a steel grade I could use in place of the f436 or if I can simply order a hardened plate and cut from it? At the same time I'm not even sure if that is legal per code and what measures I would have to take to be able to do this. Any input would help at this time while I continue my research.
RE: F436 Hardened Washers
