DLC coatings as interface
Does anyone have experience using DLC coating as a slip interface for 17-4 and titanium? The bushings in the current design are extruding under the loads and I cannot increase the dimensions. How well would this type of design wear over life?
.3125 diameter shaft by .25 wall with a 3200lb alternating load in a direction perpendicular to the axis of the shaft. 40 degree rotation. Need 2M cycles without servicing.
RE: DLC coatings as interface
The problem I am looking for expertise on is the life. I have 200K cycles on it so far and need to get to 2M minimum. I have not seen any documentation to say it will or will not make it.
