Stellite Coating for DSS
Can we use stellite/WC coating for DSS ?
Is this really required? If not, then is it a acceptable ??
RE: Stellite Coating for DSS
If not specified as a requirement by the end user, the supplier will determine the need based on the application, the service conditions and the warranty requirements. If it is not required, why use it?
To further the discussion, kolsterising could achieve a similar outcome.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Some of the low temp surface treatments that caburize, nitride, or nitrocarburize below 600F can be used on these alloys. The treatment times are long (20-50 hrs) and the layers are thin. But they are very corrosion resistant and they are very hard.
Plymouth Tube
Steve Jones
The base metal temperature (might be my assumption) will not go above recrystallization temperature.
What detrimental effect would the base metal have ?
Can we not use this laser beam technique which is welding however may not have same effect as welding on base/parent metal?
