NX9 ?: How to Pick Reference Object for Chamfer Dimension with an Offset/Angle Chamfer?
Question to those that have been in NX9 longer than I have: Anyone have the ability to pick the reference object for chamfer dimension with a chamfer that was created with the Offset/Angle Option in Modeling? As you can see from the attached JPG, I am having an issue picking what should be the reference line.
RE: NX9 ?: How to Pick Reference Object for Chamfer Dimension with an Offset/Angle Chamfer?
www.nxjournaling.com
For your situation, following the standard, you will either have to use a horizontal and a vertical dimension, or a linear dimension and angle.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
