Material A216,
Material A216,
Dear all,
I got a problem, our sepc says :
- 4" 300# Production Choke Valve, RF (Angle)
- ASTM A-216 Gr. WCB, Stl, Flg’d,
Our supplier uses CS A1020 (Casting) to produce material up to A 216 WCB, is this normal practice as chemical compositions are different, shouldn't CS A216 material be used as raw material for casting or valve body or it is too expensive ???
is our spec just refer to Standard tests as per A 216WCB ??
RE: Material A216,
RE: Material A216,
