Crossing diagonal Check for double angle when one angle continues & 1 stopped at the Gusset
Sirs
As in my earlier Quarry i requested you to advice regarding the unequal stress distribution because of one continues and one discontinues anlage in the same pair of double angles in a cross bracing.
I tried to find out the difference in stress considering the simple theory of equilibrium of forces; however i am not very sure about that.
Please look into the calculation and advice.
Mohd. Zafery
Mohd. Zafery
RE: Crossing diagonal Check for double angle when one angle continues & 1 stopped at the Gusset
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
I did some research and found that this procedure is as outlined in ASCE 10-97. Did not know that the document existed or that the procedure was valid. One article that I found referenced a program called TOWER which can be used to verify the support provided by the tension member to the compression member.
Must be a good week as I learned something new.
gjc
Zafery
