AS4100 Table 5.2 - Using a flat plate as a beam...
Trying to design a 15 x 100 flat plate bending about the major axis, spanning 2m.
Reading the background theory to plate components in the ASI connection design design guides, it's noted that AS4100 does not accommodate the situation where both edges of your plate are unsupported.
So, here I am thinking of reasons why I can/cannot consider this plate as compact.
Has anyone done this before? How can I take into account LTB?
RE: AS4100 Table 5.2 - Using a flat plate as a beam...
it would be good to get some guidance.
I set Iw = 0 and then found the member capacity. Works a treat!
