NX7.5 PDF does not work after re-load of software
When I try to export a pdf file. it acts like it is going but does not go anywhere. I have also run a search for the file.
I also tried to print and it tells me that my UGII_SDI_Base is not set correctly. What am I doing wrong?
thanks
gk
RE: NX7.5 PDF does not work after re-load of software
The error says that I am missing PDFLIB.dll
I have tried a repair and still do not seem to have this file.
NX installed fine - you've just not got the printing and plotting set up. Refer to the NX Help docs or download it from GTAC. It's an involved process and unfortunately, I don't have the time to type it all out (we're talking pages of help docs).
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
If you're missing the pdflib.dll and UGII_SDI_BASE is set incorrectly it sounds like your install is corrupted in some way (at least the plot folder is).
NXPLOT is in the folder where NX is installed. My NX7.5 plot folder is 108 MB, 531 Files, 12 Folders.
If you do a properties on your NXPLOT folder, what do you get?
Do you even have a NXPLOT folder?
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
hummmm
looks like I am missing a couple files. I have 529 files and 12 folders.
thanks guys, I was missing two files in the pdf folder and now all is well.
