NX symbols referrence in Journal
How to ref the symbols in journal
i created one journal to move all the symbols to layer 254 as following. but it is showing an error symbol is not a part of NXOPEN.Annotations.AnnotationManager
I dont know how it will read in jornal for symbols i want all the subtypes needs to be selected in this method. like crosshatch, id symbols, centerlines etc.
When i do only for centerlines or id symbols i am getting the action. But not for all.....
Option Strict Off
Imports System
Imports NXOpen
Imports System.Collections.Generic
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workpart As Part = theSession.Parts.Display
Dim hatch1 As Annotations.Hatch
Const SymLayer as Integer = 254
For each CrosshatchObj as DisplayableObject In workpart.Annotations.symbols
'if typeof(CrosshatchObj) is Crosshatch then
CrosshatchObj.Layer = CrosshatchLayer
CrosshatchObj.RedisplayObject
'end if
next
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
'end if
next
End Sub
End Module
RE: NX symbols referrence in Journal
- workpart.Annotations.IdSymbols
- workpart.Annotations.Hatches
- workpart.Annotations.Centerlines
etc, etc.www.nxjournaling.com
GD&T Symbols
Surface Finish
Intersection
Target Point
Offset Center Point
Userdefined symbols
Area fill
DMV Faceted Representation
Dim by parts
label on parent
So that I can able to extend the journal to select all individually.
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Const SymbolsLayer as Integer = 254
For each SymbolsObj as DisplayableObject In workPart.Annotations.Idsymbols
SymbolsObj.Layer = SymbolsLayer
SymbolsObj.RedisplayObject
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.centerlines
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.intersectionSymbols
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.customSymbols
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.targetPoints
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.hatches
next
For each SymbolsObj as DisplayableObject In workPart.Annotations.draftingSurfaceFinishSymbols
next
End Sub
End Module
