NX7.5 Assembly commands don't work after re-load of software
I had some issues with my machine and had to re-load / repair NX7.5.4 and now my assembly commands are grayed out. is there a toggle that I need to set to get these back?
I reloaded 7.5 as well as the 7.5.4.4 patch.
thanks
thanks
RE: NX7.5 Assembly commands don't work after re-load of software
www.nxjournaling.com
when you say the "NX Strat" menu and you talking about "File" in the menu bar? If so, I see under flie\options an assembly load options but that does not seem to do it.
thanks
