Estimation of settlement due to dewatering
Hi,good afternon dear geotech experts/civil engineers
how to estimate the settlement of soil and consoliodated time of a soil due to dewatering
the details are
maximum excavation=-6.30m
water table=-4.20m
types of shoring=h beam
k=4.62*10^-5m/s
ro=77.52m
rs=26.11m
q=.0161mcube/s
well depth =21m
pls see tha attachment for spt data
the details are
water table=-4.20m
k=4.62*10^-5m/s
ro=77.52m
rs=26.11m
q=.0161mcube/s
well depth =21m
RE: Estimation of settlement due to dewatering
In my cases most of the time the soils are layered to some extent and the drainage path is much shorter than test borings may imply. Result is, the computations generally are not very good at predicting time for the desired settlement occur. The actual time usually is well before the computations might estimate. Therefore, I depend more on test fills than any computation.
For drainage, I would think knowing the details of possible shorter drainage paths might help a lot. For a large job, perhaps a test pumping would be possible.
