How to get mass of subassembly with VBA
Dear CATIA users,
I think this is an easy one, but I've been struggling with this for a very long time now. I have a product consisting of a (1) subproduct and a (2) 3dpart. I want to get mass and inertia of (1) and (2), separately, using GetInertiaElement(). I'm able to get the mass of the whole Product and the 3dpart, but not for the subproduct... This is what I have:
' 1- Gets the current Editor
Dim myEditor As Editor
Set myEditor = CATIA.ActiveEditor
' 2- Gets the Context from the Editor
Dim MyContext As PLMAppContext
Set MyContext = myEditor.GetService("PLMProductContext")
Dim myRootOccurrence As VPMRootOccurrence
Set myRootOccurrence = MyContext.RootOccurrence
Dim myMCXParent As VPMReference
Set myMCXParent = myRootOccurrence.ReferenceRootOccurrenceOf
'3- Retrieving the PLMProductContext object as a service associated to the editor
Dim oPLMProductContext As PLMProductContext
Set oPLMProductContext = myEditor.GetService("PLMProductContext")
'4- Retrieves the list of instances within the input reference
Dim TheInstances As VPMInstances
Set TheInstances = myMCXParent.Instances
Dim oVPMInst As VPMInstance
Set oVPMInst = TheInstances.Item(1) ' Index=1 is the subassembly index #
'Getting the dynamical properties of each part (Mass, Inertia tensor, center of gravity)
Set theInertiaService = CATIA.ActiveEditor.GetService("InertiaService")
Dim theInertiaElement As Inertia
Dim theInertiaElement2 As Object
Set theInertiaElement = theInertiaService.GetInertiaElement(oVPMInst)
Set theInertiaElement2 = theInertiaElement
Dim theMass As Double
Dim theMoments(2)
Dim theMatrix(8)
theInertiaElement2.GetInertiaMatrix theMatrix ' Here is the problematic line
theInertiaElement2.GetPrincipalMoments theMoments
theMass = theInertiaElement2.GetMass
Running this will result in the error "The method GetInertiaMatrix failed". Does anyone know how I can fix this and get the mass / moments of the subassembly?
Dim theMoments(2)
Dim theMatrix(8)
RE: How to get mass of subassembly with VBA
Actually, the code above belongs to CATIA V6, so documentation in V5Automation.chm (CATIA V5 API) might not have helped.
In fact, I solved this problem earlier this week.
To compute a Product mass you have to go at higher level in the product model. You can achieve this by modifying the code I've already posted with this version:
Sub ExtractKinematicsMain2()
Set theInertiaElement = theInertiaService.GetInertiaElement(myRootOccurrence.Occurrences.Item(2))
Dim theMoments(2)
Dim theMatrix(8)
MsgBox "The Mass: " & theMass
End Sub
Thanks for your reply,
Jean-Philippe
