pressure drop, flow, darcy equation
3
book "mechanics of fluid" presents darcy equation as
h = 4 f l V^2 / d 2g
and
h = f l v^2 / m 2g
in a circular pipe, m = d/4
but I looked online, most web pages present
h = f l v^2 / d 2g
missing 4.
which one is correct?
RE: pressure drop, flow, darcy equation
It depends on whether you use the Fanning friction factor or Moody/Darcy/Weisbach friction factor. f = 4fF
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
thanks to latexman.
any one know an online pressure drop calculation page, for jet fuel, and includes angled entry and exit?
This lot are usually pretty good, but what do you mean by "angled entry and exit"? http://www.engineeringtoolbox.com/pipes-fluid-flow...
say a 2 inch pipe to 1 inch then 2 again. the cross section change is a tapered 30, 40.. degree inclusive angle.
Sounds a bit odd, but you know the details not us...
The angled entries and exits you talk of are usually called reducers (even when used in expanding mode). Sometimes they are made with a conical taper, but more often with a rounded bell shaped profile. Most piping pressure drop programs (stand alone and online) include a facility to handle pipe diameter changes using either conical resucers, pipe reducers or sudden contractions/expansions.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
