NX5 file fails to load in NX9
I am having problems opening a certain NX5 file in NX9 (I have tried hundreds of others with no problem). We use master model so there is a .prt file, and a -drw.prt file. The only component in the -drw.prt file is the .prt file... no other reference components. The .prt file opens just fine (no warnings), but the -drw.prt file will not open and I get the following errors (attached are both errors that appear). I can open them from NX5 just fine, and I have run a part cleanup on the files with no improvement. Has anyone ever seen anything like this before?
RE: NX5 file fails to load in NX9
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
