NX Journal needed To copy attribute
TO copy a attribute of a Part (For Example say callout) to a clipboard in following format <W!xxxxx@CALLOUT>
RE: NX Journal needed To copy attribute
www.nxjournaling.com
CODE
'NXJournaling.com 'October 29, 2014 ' 'select component, copy attribute reference string to clipboard 'NX 7.5 and below only! Option Strict Off Imports System Imports System.Windows.Forms Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "NXJ journal" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, undoMarkName) Dim myComponent As Assemblies.Component If SelectComponent("Select component", myComponent) = Selection.Response.Cancel Then Return End If '$$$ specify attribute title to get from component Const myAttrTitle As String = "CALLOUT" Dim myAttrValue As String Dim output As String Try myAttrValue = myComponent.GetStringAttribute(myAttrTitle) output = "<W!" & myComponent.Tag.ToString & "@" & myAttrTitle & ">" Clipboard.SetText(output) Catch ex As NXException If ex.ErrorCode = 512008 Then 'attribute not found MessageBox.Show("Attribute '" & myAttrTitle & "' not found, journal exiting", "Attribute not found", MessageBoxButtons.OK, MessageBoxIcon.Error) Return Else theSession.UndoToMark(markId1, undoMarkName) MessageBox.Show(ex.Message, "Error: " & ex.ErrorCode, MessageBoxButtons.OK, MessageBoxIcon.Error) End If Finally End Try lw.Close() End Sub Function SelectComponent(ByVal prompt As String, ByRef selObj As NXObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select a component" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination '----Other unload options------- 'Unloads the image immediately after execution within NX 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Modulewww.nxjournaling.com
