2003 planes
2003 planes
2003 planes
It defaluts to 45 degrees.
How can I reset the default to be zero degrees?
RE: 2003 planes
Since you offer no clarification here - I'll make my own assumptions.
You're inserting a plane in your part.
This plane needs to be at an angle to another plane.
You insert this new plane, using an existing plane and an axis or an edge.
The default angle is 45 degrees.
Simply type-in a new angle.
If all else fails- double-click the new plane in your feature manager and edit the angle dimension that pops-up on your model.
tatej@usfilter.com
aka: Little Debbie's Boy-Toy
RE: 2003 planes
Sorry to be so vague.
YES
NO, I WANT IT PARALLEL
YES, A MAJOR PLANE IN THE ORIGINAL SW MODEL AND AN AXIS (HOLE CTRLINE)
WHY IS IT DEFAULT AT 45 INSTEAD OF ZERO?
YER RIGHT THAT IS QUITE SIMPLE BUT I AM WAY SIMPLE MINDED AND DID IT NOT USED TO BE DEFAULT AT ZERO?
YES THAT WOULD WORK TOO.  JUST DON'T WANT TO BE BOTHERED CHANGING WHEN MOST OF THE TIME ONE USES PARALLEL PLANES.
IS THERE A WAY TO FIX IT?
RE: 2003 planes
Don't use the axis/edge.
Just use the plane you want to be parallel to.
The default shoul be a parallel plane - you select the direction.
RE: 2003 planes
If I do that I have to tell it how far from the plane but if I also pick the axis, it's done except I have to change the angle.  Probably I should just accept that this is the way it works.
RE: 2003 planes
I suppose...
Sorry, I don't have your golden ticket.
