Combining two macros
Hi All,
I need to combine two macros which are individually recorded in NX.
The first macro is recording the UDF and second macro is recording thread feature on it.
Please give some ideas to combine two macros.
Thanks in advance
Sandeep
RE: Combining two macros
I think easiest would be to record a macro which activates both macros in sequence...
Other possibility is to open them in a text editor and combine them in there... you night run into some errors when running the combined macro..
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Or maybe it would be best to write a simple journal that would execute both macros
Hi Nutace,
I did the same way you told but the macro is not working properly.
Is there any reason ?
Thanks in advance
