Metric Sizes for ASTM F1554 gr 36 Anchor Rods
I assumed the F1554 anchor rods would be available in either imperial or metric sizes (using the F1554M designation). However, we just shifted from using imperial anchors in our project to metric sizes and after some research I can't seem to find any metric sizes available. Am I missing something? We did propose to use imperial sizes but bump the size down by an 1/8th of an inch but our client wasn't too keen on that.
RE: Metric Sizes for ASTM F1554 gr 36 Anchor Rods
I am not aware of any standard metric sizes using ASTM standards. I'm not sure what the rest of the world does for this type of product. I would contact Portland Bolt to get some ideas:
http://www.portlandbolt.com/products/bent/anchor-b...
Why would you reduce the size by an arbitrary 1/8 inch?
Thank you TVP.
It was not arbitrary, I just didn't give a great deal of details. We wouldn't want to go up a size since that might interfere with the client's equipment and for many of their anchors, the closest imperial equivalent is 1/8" smaller - i.e. an M80 anchor would be downsized to a 3" diameter imperial which is 1/8" smaller.
Hello. I am the General Manager at Portland Bolt. Most ASTM specifications imply inch-series diameters, with the exception of specifications such as A325M that is written for metric product. Most of the Tables in the F1554 specification deal with imperial diameters. Examples of this are TABLE 4 Axial Tensile Properties for Full-Size Anchor Bolts and TABLE 5 Minimum Body Diameter. However, TABLE 3 Tensile Properties for Bars and Machined Specimens, offers metric equivalents for diameters and MPa for strength requirements. Therefore, one could assume that metric sized F1554 anchor bolts could be provided. Unfortunately, I am not aware of any domestic anchor bolt manufacturers that are currently producing metric sized F1554 anchor bolts on a regular bases. We ship F1554 anchor bolts outside of the country on a regular basis and often perform a soft conversion from metric to imperial diameters when the customer allows, rounding UP to the nearest eighth inch increment.
BoltExpert, thank you very much for your response and expertise. I guess we will have to rework our specification and look to international vendors in order to obtain the correct anchor rods
"in order to obtain the correct anchor rods ..."
No, "in order to get the metric size anchor bolts our paperwork rules say we must get."
Subtle, but important, difference. His anchor bolts would be "correct" but just not allowed under your company's paperwork.
No, "correct" is the word I would use to describe the anchor rods that my client (who pays for them) wants. We tried the soft conversion route and if they have their reasons to want exact metric sizes then I will (and must) respect it. In other words, the "correct" choice is always what the client wants as long as it is safe and offers them a benefit.
