Butterfly Valve Body thickness as per ASME B16.34
Hi Guys,
Can anyone tell me how to interpret the terms mentioned in Fig 17 of ASME B16.34.
What exactly is t1' and t2' ?
Karthik
Karthik
RE: Butterfly Valve Body thickness as per ASME B16.34
Thanks for the reply.
tm is the minimum wall thickness based on bore diameter mentioned as per table 3A & 3B.
t as per 16.34 should be more than tm. That too is fine.
Now what about t1' and t2' , how do we arrive on these values. Only when you arrive on these values you can calculate e,f' & g'.
ARK.
