Device to cut power if load lasts longer than set time
I'm having some trouble finding an off the shelf product that I would think would already exist.
I have a 1/2 HP, 120V pump that will be moving fluid from one tank to fill another, until a float switch in the filled tank cuts power. As a safety backup, I would like a product that will cut power to the pump (until manually reset) if it runs for longer than a set time. The idea being, if the pump runs for too long, it means something in the system is screwed up (tube burst, tube fell onto the floor, etc...) and the pump is now evacuating the tank all over the lab floor.
Does a product like this exist? I know I can rig something up using timing relays, but that will require additional time and effort that may not be necessary.
RE: Device to cut power if load lasts longer than set time
The function you are looking for is called "single shot leading edge, voltage controlled" in this little demo page.
http://es.eaton.com/EatonTiming/app.htm
http://www.eaton.com/Eaton/ProductsServices/Electr...
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
The more traditional way, I think, is a pressure switch on the pump that cuts off power if the backpressure seen by the pump goes too low. You still need a timer to prevent it from opening while the pump comes up to speed.
Mike Halloran
Pembroke Pines, FL, USA
But honestly, those would likely cost more than the timer.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
