Formboard layout
Formboard layout
Hi.
I need to create a formboard drawings of harness files.
I have situation where I need to create a formboard layout of a larger harness file which fits in the single screen.When I do fornboard layout,the harness will be flattened and it will have main limb running straight and all the sub limbs orirnted at angles to the main limb.As far as I tried I could only orient smaller sublimbs at angles.
But I need the main limb to be folded(not in box shape,it should be like semi circle) like as we fold the harness in practical situations to make it fit in a single pdf.The reason is it would be easier to see the entire details of a larger harness in a compact space.
Could anyone help in this regard.
Thanks in advance
Sri
Thanks in advance
Sri
