Relations Browser not working in NX9
Is it true that the relations browser for wave is broke in NX 9.0.2.5 Rev C. That’s what my IT guy is telling me. When I run the relations browser I get this error.
>>>> Error code 3600029 caught in file "D:\workdir\reference\NX902_5\src\assyutilsint\no\ind\ui_assy_utils.c" at line number 776
>>>> Error code 3600029 caught in file "o:\ugnx902\ip5\src\ugui\no\ind\mb_callbacks.c" at line number 1884
>>>> Error code 3600029 caught in file "o:\ugnx902\ip5\src\ugui\no\ind\mb_menubar.c" at line number 1671
>>>> Error code 3600029 caught in file "o:\ugnx902\ip5\src\ugui\no\ind\uigblfunc.c" at line number 278
>>>> Error code 3600029 caught in file "D:\workdir\reference\NX902_5\src\modlint\no\ind\ui_modl_app.cxx" at line number 513
&MACRO FOCUS CHANGE OUT 1
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2, Error recovery completed for the following error:
&MACRO MESSAGE_TEXT No Java Author License is available to be able to run this java class file.
The NX is installed on the server.
I do not have a “D” or and “O” drive.
The versions of Java that I have is 1.7.0_21 I tried a newer version 1.7.0_65 but that broke my help files so I switched back to 21.
RE: Relations Browser not working in NX9
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
this seem s to be a problem with the GMtoolkit,
check (search for) UGII_JAVA_HOME from Help->logfile if the folder exist
The GM environment uses JAVA 1.7.0_55, (per Siemens, any 1.7.0_XX above 55 should work but JAVA 1.6 and 1.8 are not supported at this time). GM also highly recommends you do NOT set JAVA to auto-update as even Oracle’s minor JAVA 1.7 updates earlier this year have caused security warnings and errors.
I would check if updating to the specified Update 55 fixes it. Also make sure that you have the following variables set to the right locations for your Java install.
In my case they are:
UGII_JAVA_HOME C:\Program Files\Java\jre1.8.0_25
UGII_JVM_LIBRARY_DIR C:\Program Files\Java\jre1.8.0_25\bin\server
As for your help, we made a video a while back that explains how to fix the Java issues for the documentation: http://vimeo.com/91380605
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
I had a customer of mine ring in with the same problem as you and the fix was to set the variables correctly
Anthony Galante
Do you still get the same error as before or has the error changed?
Anthony Galante
This error is caused by a missing signing for the Java Jar file:
"NX 9.0\nxassembly\NxBrowser\server.jar"
The issue will be fixed in NX 9.0.3.
If urgent GTAC can make a signed server.jar available.
Our licenses have a java_author license so that's why I couldn't see the error.
When I tested with a license without java_author, I got the error message you've been seeing.
Solution is to update to NX9.0.3 (I know GM is 9.0.2.5 Rev C) or contact GTAC, refer to PR 1992230 and ask for a signed server.jar file.
Anthony Galante
