Shear Stress in Pipe Flow
I was reading a paper on the strength of paraffin gels formed in pipelines, and I came across a part that said, "In a pipeline, a shear stress of 5 Pa would be exerted on the incipient gel deposit by an oil flow rate of approximately 16,000 barrels oil per
day in a 10-in pipeline with an oil viscosity of 10 cp (mPa s)." (Venkatesan et al., 2005)
I calculated the Reynolds Number as Re = 12544 with an oil density of 850 kg/m^3. I understand that this implies that the flow is turbulent. I'm not sure how they calculated the shear stress. I don't think I can use shear stress formulas for laminar flow to calculate the shear stress in this case. I have attached the paper; the above statement can be found on page 8.
RE: Shear Stress in Pipe Flow
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. —Galileo Galilei, Italian Physicist
