After migrating to NX 9 doubling cliking NX part file does not launch NX
If I have a session open it works, but otherwise it just says routing to application and sits there.
Do I have to reinstall NX?
RE: After migrating to NX 9 doubling cliking NX part file does not launch NX
Take a look at the .syslog file fo the router - same place as NX syslogs.
If no sessions are open, it should start the most recent locally installed version of NX.
For example:
INTEROP: Executing: D:\Program Files\Siemens\NX 10.0\ugii\ugraf.exe
Be sure this file exists.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
For some reason it is pointing incorrectly to the General Motors install instead of native NX.
This isn't even the proper launch file location for the GM environment.
INTEROP: Establishing client-proxy for interoperating
INTEROP: Attempting to interoperate with Unigraphics V27.0 1...
INTEROP: Waiting for Mutex: UGS Mutex Unigraphics V27.0 1
INTEROP: Obtained Mutex
INTEROP: Executing: R:\data\cadsite\nx9\scripts\start_ugii.bat
INTEROP: Waiting for Unigraphics V27.0 1 to start up...
*** EXCEPTION: Error code 3070023 in line 536 of o:\ugnx902\ip5\src\interop\no\ind\interop_socket_writer_definitions.c at Wed Oct 29 05:44:53 2014 Eastern Daylight Time
+++ Interrupted whilst waiting for: R:\data\cadsite\nx9\scripts\start_ugii.bat
In a similar situation that I once encountered, I used "filetypesman" and changed the default program to open prt files with this line: "C:\Program Files\Siemens\NX X.X\UGII\ugs_router.exe" -ug -use_file_dir "%1"
where X.X stands for the version of NX that you use.
It was already set to "C:\Program Files\Siemens\NX 9.0\UGII\ugs_router.exe" -ug -use_file_dir "%1"
