SLENDERNESS Error in STAAD output
Hi everyone, I'm working on a STAAD model. I have some horizontal bracing in the model along with vertical bracing also. I am getting a SLENDERNESS Error for some of the braces even though the slenderness ratio is less than 200. I calculated the ratio manually. I'm not understanding why I'm getting this as a failed member.
RE: SLENDERNESS Error in STAAD output
