identifying the element/connection with grid id
*** USER FATAL MESSAGE 5289 (WRGMTD)
DEPENDENT DEGREE-OF-FREEDOM GRID ID = 4197379 AND COMPONENT = 1 APPEARS ON MORE THAN ONE MPC OR RIGID ELEMENT ENTRY.
How to identify the element/connection that is causing this error
prashant bhushan
prashant bhushan
RE: identifying the element/connection with grid id
Remedy:
You need to search thro' your model for the grid 4197379 and locate those multiple rigid/mpc elements which share the same grid id as a dependent node at d.o.f 1, and manually correct them to make sure that there is only one rigid/mpc element which refers to grid 4197379 at dof 1 as a dependent grid.
OR:
Use param,automset,yes entry in your bulk data section of the input file and allow nastran to internally repair the global m-set.
My problem is how to search through the model for that particular grid....
Prashant bhushan
It is at this point that you need to pick-up the user guide for the pre&post that you use and read-through.
thanks for the advice; it really helped me.
Prashant Bhushan
