Unbraced length of girders supporting a monorail
I'm working on a frame right now that has 4 monorails on it. There are girders with S section monorails bolted to the bottom flange of the girders. I have these modeled as fixed moment connections but my question is about the unbraced length of the girder. Right now I am assuming the beam is unbraced across the entire length, even though the bottom flange is "brace" by the top flange of the monorail. Does this seem like a reasonable approach?
RE: Unbraced length of girders supporting a monorail
1) You're confident that the connection between beams can couple monorail flexure to girder torsion and;
2) You evaluate the stiffness of the monorail bracing scheme for it's suitability as bracing. AISC has checks for that.
Note: I'm not especially well versed in industrial work.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
The girder unbraced length should be 38 to 40 and 40 to 41.
I'm also modeling it defining all braces as truss members as opposed to tension only because I get instabilities due to "leaning of structure" because eccentric loading. I get some failures of 2L4x4 angles under compression. adding more braces my help that but then again, not saving any money because I'm adding more connections and steel.
