Post forming heat treatment according to Russian codes
Hi everybody
I would to ask you the following issue:
I have to manufacture some pressure vessels for Russian project.
The material is SA 516 gr 70N
ID 677mm
thk 17mm
the applicable code is ASME VIII div 1 + russian codes
The Client is asking a Post Forming Heat Treatment because, he say, for Russian codes the vessels manufactured by plate rolling according to point 4.4.4 of PB 03-576-03 have to be heat treated
Can I have your opinion ?
Bye
ID 677mm
thk 17mm
Bye
RE: Post forming heat treatment according to Russian codes
