Need urgent help..i am in mess..please help me to solve this problem
Hii frnds..problem cming at output side of delta ec3 plc (8inputs,8 outputs).
Output is not exciting relay coil.tested with micro relay also.same result.i have given +24v at output commons(source)..kindly tell me what should i do..
At output of plc,0v is coming instead of +24v bcz comm is positive.i changed the other end of coil but no result...
Kindly help me urgently..
Best regards!
Best regards!
RE: Need urgent help..i am in mess..please help me to solve this problem
I suggest you contact the manufacturer or supplier of the Delta PLC.
