impeller dia and system curve
say there is a 12 inches dia impeller installed in a pump there will be a system curve and the operating point will be the intersection of these two
now, say we replace the larger impeller with a smaller impeller, will the original system curve also change or remain the same?
thank you
RE: impeller dia and system curve
Changing the impeller diameter does not change the system curve.
Johnny Pellin
I think that you meant is pump performance curve and not system curve, however, I don't want to second guess.
for chicopee
no i did not mean performance curve, i meant systems curve in the second case.
thank you
Tomoto5,
The answer is fairly clear, why would the system curve change when nothing in it has changed?
This is a simple question so gets a fairly simple answer. Is there something more complex behind this that would cause you to think differently?
thank you very much
aamir
No worries, you didn't hurt any feelings.
bimr your attachment was most useful
