MV Service Disconnect
In an industrial site where the utility provides a primary metered service - 4 wire grounded wye to a single pad-mount transformer. Is a gang-operated load break switch - pole mounted - suitable to serve as the service disconnecting means? Or is a padmount switch or switchgear lineup required. The utility will be providing metering upstream of this disconnect, on the pole, so no metering compartment required.
RE: MV Service Disconnect
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". – Nikola Tesla
