NX9 - Measure Distance
Why is it that every time I start NX9 and attempt to use Measure Distance does it default to one of the Simple Measurements (Simple Radius)?
If I wanted a Simple Measurement, I'd go to the More gallery.
Have I inadvertently saved a favourite ?
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: NX9 - Measure Distance
You probably have set it to simple....See picture.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Measure Distance then worked okay. However, after using Simple Diameter or Simple Radius, if I then choose Measure Distance, it displays the last "Simple" dialog that I had used.
The same happens if I use Angle rather than Distance, I get stuck with Simple Angle.
NX 9.0.3.4
NX 10 (Testing)
