ASR in concrete
ASR in concrete
We have an elevated tennis court, 6 years old, constructed of 2" metal deck with 4" total thickness of concrete. There is severe ASR finish damage. We want to resurface the concrete by removing +/-1 inch of concrete and replacing with a fully bonded concrete finish. Our concern is the ASR will remain in the original concrete and bond to the new concrete, temporarily. Between the micro cracking damage caused by the concrete removal and the fact that this is an exterior deck, we believe the ASR will continue to react and create additional damage after resurfacing. Our second choice is to remove the concrete and metal deck and begin from scratch. The concrete fill is non-structural as the metal deck meets vertical and lateral requirements as a bare deck. Has anyone been faced with resurfacing over ASR contaminated concrete and if so, was it successful?
RE: ASR in concrete
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
RE: ASR in concrete
An exterior elevated slab on metal deck and the slab is non-structural? I don't know the environment, but I would be leery about the life expectancy of the metal deck, galvanized or not. The slab should be reinforced if it is exposed to the outside environment.
As far as the ASR - that slab has to go. Placing a topping over it is just asking for a repeat performance in a few years.
Ralph
Structures Consulting
Northeast USA
RE: ASR in concrete
