Pro Batch won't work when I hit start pro batch
I run proe 2001 on windows 98. I have recently tried to get pro batch running. When I hit OK on the start pro batch box all that happens is a system window opens and the directory changes to d:\p..files\proe2001\bin. Any ideas???
RE: Pro Batch won't work when I hit start pro batch
When you are in the system window, what happens when you type in pro_batch? We are using 2001 on Win 98 - don't have any problems getting to the batch UI. Getting pro batch to work the way you want it?.....that takes a bit fooling around.
JW
