Two different results for the same Stress output in python
Hi All
when I use this code after my analysis , I only can get the results on integration points
myViewport.odbDisplay.setPrimaryVariable(field=stress,outputPosition=INTEGRATION_POINT,refinement=(INVARIANT, 'Mises'))
but from this one the stresses are available on all options :
field.getSubset(region=elements1,position=CENTROID)
I need to use the first one because I want to print the results on tiff
also I have another problem with sessionPrinttoFile() that i get windows error whether the destination folder can not be found, (whaatever I change the directory to ) , or it says permission denied
I use windows 8
related ?
