Mirrored Assembly
Mirrored Assembly
Mirrored Assembly
Hi there, ok I created a frame generated weldment made from 40 x 40 x 5 angle, placed this in my main assembly, then mirrored it...fine.
I have now decided to change the original frame and use 40 x 40 x 3 angle, which is good, but the mirrored version does not update to represent the change, and it remains as 40 x 40 x 5 angle.
I would have thought this would update. Have I missed something??
Many thanks in advance
RE: Mirrored Assembly
you don't miss something, the mirrored part in frame gen in not associative to the original. delete and mirror again.
Cheers for that cgelang
