NLgeom ''On'' effect on the calculated reaction force
thread799-158806: Element Matrix Output in Elastic NLGEOM Analysis
Hi
In a large, non-linear deformation of a spherical capsule, when I use NLgeom, at the end of simulation, I get a linear Force-Displacement graph. This is strange, because I know that in this case, force-disp relationship should be closer to that of a second order curve not a line.
Do you have any suggestions why this happens?
Best,
Biofemer
Hi
Best,
Biofemer
RE: NLgeom ''On'' effect on the calculated reaction force
Likely we will need more details to help more but here are a couple of my thoughts.
You mention NLgeom 'at the end of the simulation' Do you not have it on the whole time?
Do you have non-linear material properties such as hyper-elasticity?
I hope this helps.
Rob Stupplebeen
www.optimaldevice.com
https://sites.google.com/site/robertkstupplebeen/
Sorry for the confusion caused by the structure of my message. The NLgeom is "on" during the simulation. But, The results that I get at the end are not consistent with my expectations.
The case that I am simulating is the deformation of an axisymmetric shell between two rigid plates. The shell is elastic and meshed with CAX4RH elements. Therefore, the deformation is not linear. Then I need to use NLGeom for reasonable results in terms of deformation. The visualization of deformation is fine with NLgeom "on" but not acceptable when it is off.
For more details I can also attach the .inp files if required.
cheers,
Biofemer
Rob Stupplebeen
Plaese find attached the *.INP file of the mentioned case.
I have always used NLGEOM whenever I'm modeling contact. I hope this helps.
Rob
Rob Stupplebeen
Thank you!
As you see, in your Force-time graph, the "linear" curve, which you probably obtained by toggling nlgeom "off", is more non-linear ( force magnitude-wise uplifted compared to the linear relationship that you can get by extrapolating the common linear part of the two graphs which occurs in very small deformations) than what you got by using nlgeom "on".
Besides, regarding the physics of the problem [1] the blue curve can not be correct.
Reference:
[1] " Determination of the elastic properties of single microcapsules using
micromanipulation and finite element modeling " by Ruben Mercade´-Prieto, in Chemical Engineering Science 66 (2011) 2042–2049.
Unfortunately I do not have access to the reference you provided. In the reference and in your case is the sphere filled with a contained fluid or gas? If so a fluid cavity will be needed.
With the very large deformations as shown in the image below any simulation without NLGEOM is suspect. Personally I would turn it on and work on the fluid cavity and providing a hyperelastic material model for the rubber.
I hope this helps even though I am not directly answering your questions.
Rob
Rob Stupplebeen
