Variable Friction Coefficient
I have a situation where the friction coefficient increases linearly until it reaches its final, steady-state value.
There is also difference in the friction coefficient values with different temperatures.
Is there a way to input coefficient values like that? (i.e. essentially changing with contact force). I can see how to enter temperature-dependent coefficients in the penalty tab of tangential behaviour but not load-dependent.
RE: Variable Friction Coefficient
In the penalty tab of tangential behavior see 'use contact-pressure-dependent data. I have never used both dependencies but would assume that Abaqus makes a linear response surface based on the inputs provided. The user manual likely goes into more depth.
In the Abaqus/CAE manual '15.14.1 Defining a contact interaction property' may be a good starting point.
I hope this helps.
Rob Stupplebeen
www.optimaldevice.com
https://sites.google.com/site/robertkstupplebeen/
Thank you Rob!
If the dependence get very complicated you should be able to use the FRIC user subroutine as well, though Rob's suggestion is definitely the preferred way.
Han primo incensus
