Advanced assembly constraints
Hi there . .
I just want to ask you about advanced assembly constraints . For example ,if I want to constraint pistone movement between two specific points which have specific distance to the top of compressor ( in the example ) .
what can I do to handle this situation .
Thanks in advance to your replies .(notice that I do not have motion simulation license)
M .Rummo - Turkey .
NX 9 - windows 7
RE: Advanced assembly constraints
I just want to do something like (limit distance)
you may have a look at arrangements.
keep in mind these assembly constraints are positioning constraints -
hope it helps
How could I use Arrangement to define the maximum and minimum distance of te pisone movement .
please attach a video or some thing else.
thanks for your reply .
Thank you very much .
